Hi all! I have some troubles when using x264. The total number of frames between source and encoded are the same, but the frames inside are different. This lead to audio delay. Please check the attached images.
I used avisynth 2.5.8 (also tried 2.6), x264 r2334 on x264.nl (also tried the latest r2538). My encode setting:
I also tried x264 8bit without avs2yuv, also tried x265, but everything is the same. Can anyone help me? Thanks.C:\avs2yuv.exe encode.avs -o - | C:\x264.exe --stdin y4m --crf 23.5 --stats ".stats" --level 4.1 --ref 11 --no-fast-pskip --bframes 6 --direct auto --deblock -3:-3 --subme 9 --trellis 2 --psy-rd 0.8:0.0 --me umh --aq-strength 1.0 --no-dct-decimate --no-mbtree --output "crf4.mkv" -
It used to be known widely that FFMS2 can't handle M2TS well, even if Haali Media Splitter is installed. You should either use FFMS2 only with MKV sources, or use a different source filter for M2TS (e.g. L-SMASH Works, or – if you can afford it – DGDecNV or DGDecIM).
This may not have the same relevance anymore if you are using one of the latest (test) versions of FFMS2 where the dependency to Haali got removed, so that it uses lavformats as splitter instead, like L-SMASH Works (LwLibavVideoSource) already does. -
Thank LigH.de, I used LSMASHsource (LwLibavVideoSource) and It worked like a charm
AVISynth TRIM results in wrong frame number in VirtualDub
By Budman1 in forum Video ConversionReplies: 33Last Post: 15th Jun 2014, 15:24 -
Frame error with x264
By ROBO731 in forum Video ConversionReplies: 2Last Post: 15th Jul 2013, 15:33 -
show x264 command line output when using megui as x264 gui
By codemaster in forum Video ConversionReplies: 4Last Post: 12th Mar 2013, 10:35 -
Play an MTS file frame by frame, displaying timecode or frame number
By SeánB in forum Software PlayingReplies: 5Last Post: 5th Oct 2010, 16:26 -
Problem - "Wrong frame length"
By IllusionOfLife in forum Authoring (DVD)Replies: 9Last Post: 10th Jul 2010, 02:09
